Crlee71
#1 Posted : Tuesday, December 10, 2013 1:52:12 PM(UTC)
Crlee71
I have a Kenmore 80 series washer. It made a grinding noise during the spin cycle then quit spinning. I checked the coupler and the plastic piece cracked. I ordered a coupler from appliancepartspros.com and replaced (got the 2 plastic pieces and the rubber piece). I tapped the plastic pieces on like the video showed. Then tested it. The first run, a whistling noise occurred during the spin cycle. So, I took everything back apart to get to the couplings and tapped the plastic pieces a little bit more. I gave it another test run, the whistle came then went during the spin cycle, but now smells like burning rubber during it. Any ideas or suggestions?
fairbank56
#2 Posted : Tuesday, December 10, 2013 2:13:32 PM(UTC)
fairbank56
Groups: Expert
Couplers not on far enough. They must be on far enough so that the hub of the plastic pieces are just a hair past flush with the shafts.
Eric
