Dmalone1949@gmail.com
#1 Posted : Sunday, December 8, 2013 1:40:51 PM(UTC)
I suspect that the 3-position thermal switch on my dryer is not working right. How do I test it with my electric meter to see if it is working correctly in all 3 positions? I have had some issues with the dryer running but no heat.
dab147
#2 Posted : Monday, December 9, 2013 6:27:28 AM(UTC)
dab147
You most likely have bad coil kits that open up electrically and this and sometimes take time.Like the dryer works ok for one load than no heat or half a load than no heat.Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
