jyvez
#1 Posted : Thursday, December 5, 2013 7:20:55 PM(UTC)
jyvez
Bottom freezer gasket completely came off the door liner. I pushed the gasket back in but its still loose and if I give it a slight pull it comes off again. I noticed that the liner edge slightly separates from the door very easily. Is the door liner broken and can it be replaced? or the gasket needs to be replaced?
#2 Posted : Friday, December 6, 2013 8:58:36 AM(UTC)
Parts for Whirlpool W8TXNWFWQ01 Refrigerator - AppliancePartsPros.com
The freezer gasket is item 14 in section 02.
Click on the correct color gasket picture or description you need and a new page will open with more info, views and a video.
You may find the video helpful.
You cannot just replace the door liner, you would have to buy a new door.
I cannot say what the problem is but it looks like they may have redesigned the gasket so a new one may fix the problem.
#3 Posted : Sunday, December 8, 2013 3:50:59 AM(UTC)
Put some silicone cement on the door liner channel, close the door and let it dry for a few hours, should fix the problem and save money.
