hofers7
#1 Posted : Friday, May 1, 2009 5:34:26 PM(UTC)
hofers7
came home and had a puddle of water outside fridge i emptied fridge . cleaned coils now it won't get cold fan running any help
AIMANNY
#2 Posted : Friday, May 1, 2009 6:02:16 PM(UTC)
AIMANNY
is the frezzer fback wall frost up
woodchuckie
#3 Posted : Friday, May 1, 2009 7:19:46 PM(UTC)
woodchuckie
Check to see if the condenser fan at the back underneath the fridge is running.
Is the compressor motor near that fan running.
Are the coils warm ,cold or hot.
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere.
hofers7
#4 Posted : Saturday, May 2, 2009 10:35:16 AM(UTC)
hofers7
yes the fan is running the coils are warm the evap fan is also running and the coils are clear no frost no ice nothing
hofers7
#5 Posted : Saturday, May 2, 2009 10:38:14 AM(UTC)
hofers7
fan is running coils warm evap fan also running clear on coils no frost or ice
#6 Posted : Saturday, May 2, 2009 1:36:57 PM(UTC)
If the compressor is running, but there is no frost on the evaporator coils then the problem most likely is with the sealed system. It could be low on Freon or the compressor has low capacity.
hofers7
#7 Posted : Saturday, May 2, 2009 4:14:36 PM(UTC)
hofers7
where do i go firm here any switches or relays that would cause this condition
Guest (4)
