Idaho Dan
#1 Posted : Saturday, December 7, 2013 1:50:10 PM(UTC)
Idaho Dan
Noticed water coming from freezer side, confirmed it wasn't freezing and frig stopped cooling. Powered off and turned temp to coldest setting and fan started up on freezer side and hour later frig started cooling. Been working for three hours no issue on either side.
what would cause unit to stop and then reset, not comfortable leaving with this situation, any ideas
#2 Posted : Sunday, December 8, 2013 12:24:48 AM(UTC)
Here are your parts.
Parts for FRS26ZTH - AppliancePartsPros.com
You seem to be missing a couple digits at the end of your model number so you will have to choose the correct one from the Matching Model Numbers section.
Sounds like the temperature control thermostat is sticking open.
I would replace it.
