tdm757
#1 Posted : Tuesday, December 11, 2007 4:14:31 PM(UTC)
tdm757
Over the Range Microwave went dead while exhaust fan only was running. No power at all going to unit. Control board has no function working or showing signs of power. In the inside of the computer control panel there is a wiring diagram, and based on the wiring and testing criteria; the thermal fuse, capacitor, diode, fan motor, and on the transformer, the primary and filament wiring test ok. I didn't test the secondary wiring of the transformer, as it is covered with a tape protective covering.
There is a MGT THERMAL FUSE shown in the wiring diagram, but I can't find it. Could that be the issue?
The secondary switch didn't doesn't appear to make contact with the door, so I held the switch down, and still no power to the unit. This might be an auxillary problem.
Is it possible that the $175 control board is dead? How do I test it for sure?
Any other ideas?
This one has been a learning experience for me, as this isn't my cup of tea. This board has been very helpful, and I hope someone can help me.
#2 Posted : Tuesday, December 11, 2007 6:33:36 PM(UTC)
Did you check the line fuse?
Did you check the power outlet for 120V?
The magnetron thermal cut off is mounted to the magnetron.
rr Johnson
#3 Posted: : Tuesday, December 11, 2007 6:50:05 PM(UTC)
rr Johnson
I was cooking Oatmeal this morning. after 20 seconds, the 6 year old GE emo3000cbb lost all power. The is still power at the plug. any Ideas?
signed,
cold oatmeal
#4 Posted : Tuesday, December 11, 2007 7:00:23 PM(UTC)
The first thing I would do is check the line fuse.
- Here are the break down diagrams for the GE microwave Model EMO3000CBB02
tdm757
#5 Posted : Wednesday, December 12, 2007 10:30:53 AM(UTC)
tdm757
In my post, it incorrectly states that I checked the thermal fuse. I checked the line fuse, and it shows continuity. From the plug to just before the line fuse where it connects to the case reads 120V.
Any other ideas???
TM
#6 Posted : Wednesday, December 12, 2007 10:45:10 AM(UTC)
TM
Did you check the cavity thermal cut off (#7 on the interior break down diagram)?
rr Johnson
#7 Posted : Wednesday, December 12, 2007 4:11:54 PM(UTC)
rr Johnson
thanks Gene, it was the fuse. What causes this?
#8 Posted : Wednesday, December 12, 2007 4:25:33 PM(UTC)
Overheating or loose wire connection.
