Hello, I have a Bosch SilencePlus dishwasher.
The tub does not empty, the soap dispenser does not open and it goes to "clean" about 1 minute after I start it. I just unhooked the drain line and drained the water. I ran the drain line into a bucket under the sink. I started it and It ran a cycle and pumped the water out but after a few minutes it stopped and said "clean." I switched from "auto wash" to "normal wash" and started it again. It seems to be working for a while then stops. Any ideas? Thank you Wayne
having the same problem, so will be following this thread and hoping for a reply!
