Felony
#1 Posted : Tuesday, December 3, 2013 8:29:13 PM(UTC)
Felony
My fridge is freezing food, top shelf, bottom drawers, and door. I replaced the damper in the top and the thermostat that goes with it. Still freezing. Any suggestions?
#2 Posted : Wednesday, December 4, 2013 1:04:35 AM(UTC)
Post the stabilized freezer temperature.
Felony
#3 Posted : Wednesday, December 4, 2013 6:05:37 AM(UTC)
Felony
I placed a thermometer in the freezer for 2 hours. The freezer temp is 2.2 degrees.
#4 Posted : Wednesday, December 4, 2013 7:11:29 AM(UTC)
Seems normal to me. Only other thing is the air flow into the fridg section may be lower than normal. Check all air passages for an ice jam.
Felony
#5 Posted : Wednesday, December 4, 2013 7:30:48 AM(UTC)
Felony
I am not finding any obstructions. I have noticed that the damper on top between the freezer and fridge always seems to be blowing? Since I replaced both the damper and thermostat is there anything else that controls the damper?
#6 Posted : Wednesday, December 4, 2013 8:47:29 AM(UTC)
You most probably have a bad control board behind the control panel. Remove the control panel overlay and the 4 screws, then you will see the board. Order one here.
