ive got a Maytag MZD2665HEQ, i replaced the Overload/Relay and Start Capacitor, i also bought the run cap but the refer doesn't have one or at least i haven't found it even though sites says it does, b4 i replaced relay/cap i wouldnt start period, after it now it at least starts and it cools down but it never finishes cooling all the way as far as i can tell b4 the compressor starts hanging up for lack of better term, it sounds like comp wont start backup and it just does this in endless loop, till i unplug and leave it for a bit unplugged then when i plug it back in it fires right back-up no lags comp just auto engages no problem for a few hours then it goes back to not working
You have a damaged compressor with shorted turns, probably best to get a new fridg.
