Ene
#1 Posted : Monday, November 4, 2013 5:13:15 AM(UTC)
Ene
I was washing yesterday and after 3rd load my washer stopped before rinse cycle, it is not spinning the water out. It dose wash , but not spin. No I am not sure how to get the water out, and if I could fix this problem home or should I call the repair man.
fairbank56
#2 Posted : Monday, November 4, 2013 5:38:55 AM(UTC)
fairbank56
Groups: Expert
Probably a bad lid switch. The type used on your washer is prone to coming apart. It can be glued back together or cinched with a small tie-wrap, or you can just replace it.
Whirlpool 3949238 Lid Switch Assembly - AppliancePartsPros.com
Eric
Ene
#3 Posted : Sunday, December 1, 2013 12:56:11 PM(UTC)
Ene
So today I had finally had time to change Lid switch as recommended by fairbank56.
Thank you very much for you prompt replay and easy part order link. I used the video as a reference as I worked and everything fit in to place perfectly.
Now I am happily washing my close again, thank you very much!
