If someone could get this to Denman, I would appreciate it.
Denman, I was here several days in late August and September (this year, 2013) working on my electric range. You gave me a lot of help, and I wanted to say a big THANKS! ----It took me a couple of weeks because I only had some blocks of time to work on it, and it took me several iterations to find out what the exact problem was, and then repair it. ----Net, I got the job done (it was inoperative heating of all elements of my range, ---http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/534118-no-heat-either-oven-elements-range-top-but-power-lites-switches-elect-contro.html#post827332
I won't bore you with the details, but needless to say there were a couple of fruitless attempts/ alternatives and some stumbles to me not being so bright, but I got it done and all is working great.-------Made a slow and low roasted pork shoulder tin the oven the other night for faux bbq/ pulled pork.
Your help saved me a lot of time getting to the problem / solution---and most likely to get it done at all; saving me a large repair bill.
Thanks again!
JB (user name Younger G.)
You are welcome. I am glad to hear that you are up and running. |
THIS FORUM IS DEAD!!!!!!! |
denman, thanks for the quick reply and information you provided, wasen't sure on the felts on the front & rear of the drum but there are marks, will check them out further. Also a big thanks for the link to testing the last resort almost, the motor, very valueable info. Thanks so much again. ;)
You are welcome.
If you could lets us know what you find. That way others with a similar problem will see what actually fixed the unit instead of just suggestions about possible causes. |
Originally Posted by: denman  You are welcome. Okay will do. Might be about a week though need to get some cash together. :)
