imphuzzy
#1 Posted : Monday, November 25, 2013 12:57:09 PM(UTC)
imphuzzy
Turn on oven thermostat to 400°. Ignitor starts to glow and after a minute or two, burner ignites. Then oven goes into a cycle of good solid flame for about 1-2 seconds and it drops back down to hardly visible (as if set temperature was reached). Stays that way for 30 seconds and full flame comes back on for 1-2 second, and then down to minimal flame again. Oven never reaches set temperature and it takes forever to cook anything. So is the problem with the temperature sensor, the oven thermostat or the control wiring to the gas valve?
Then there's the issue of getting parts for a 27 year old stove...
Appliance Ninja
#2 Posted : Monday, November 25, 2013 1:07:39 PM(UTC)
Appliance Ninja
I suspect you actually have an issue with the oven igniter. Even though it glows, it has to draw ample current through the bimetal in the valve to open it and keep it open. I suspect that the igniter is getting weak and is unable to keep the valve open. You can test the current draw with a clamp on style ammeter, looking for at least 3.0 amps, preferably 3.2-3.8. If it is not drawing at least that current, the igniter will need to be replaced and is available below.
Whirlpool 12400035 Flat Style Oven Igniter Kit - AppliancePartsPros.com
imphuzzy
#3 Posted : Wednesday, November 27, 2013 5:43:05 AM(UTC)
imphuzzy
Even though I just changed the ignitor about a year ago (previous one had no continuity and wouldn't glow at all), and being that this is about the only part still available I have a new one arriving today. I'll let you know how it goes. Thanks.
Update.... Thanksgiving morning I installed the new ignitor and now it works fine, and I get to play hero. Thanks again!
-Michael
imphuzzy
#4 Posted : Friday, November 29, 2013 8:11:16 AM(UTC)
imphuzzy
Update -- Thanksgiving morning I replaced the ignitor and everything works fine and I get to play the hero. Thanks again!
imphuzzy
#5 Posted : Friday, November 29, 2013 8:11:18 AM(UTC)
imphuzzy
