The washing machine will not run. the lights come on but do not work
Groups: Expert
This washer does not have a simple mechanical timer, it has an electronic control unit. Retrieve the tech sheet from inside the cabinet and follow the procedures to place it in service mode to check for error codes and run troubleshooting tests.
Eric
