I have a Maytag Neptune dryer model MCE8000AYW. It will not start.
When I press the Start button, it just makes a clicking sound.
The top portion of the drying cabinet works fine.
The control panel works and the diagnostic code result returns SOL and End (nothing).
I ran a Logic Board Output Self-Test (Lo) and both top and bottom return PASS.
We reset to factory defaults and still nothing.
I opened the front case, cleaned out all the lint.
I removed the Thermal fuse and tested for continuity and there is continuity. I put the thermal fuse back on. I also tested the door switch and the continuity was also good.
Any other testing suggestions or help would be appreciated.
Thank you, Buckeye 597
Forum Rank:: Member
I'm having the exact same symptoms and test results. Just curious if you figured out what was wrong?
Is anyone answering this? I have what sounds to be the same problem.
Forum Rank:: Member
Originally Posted by: mijnomrah I'm having the exact same symptoms and test results. Just curious if you figured out what was wrong? I ended up fixing it myself. Both the thermal fuse and heating element needed to be replaced. The heating element is no longer available so I had to use a restring kit which wasn't was hard as I thought it would be. I spent about $80 in parts.
