2 Pages<12
plout99
#11 Posted : Saturday, November 23, 2013 5:52:54 AM(UTC)
plout99
I removed the starter for the compressor and it clicks/rattles when you shake it.
Thanks,
Jeff
Appliance Ninja
#12 Posted : Saturday, November 23, 2013 7:45:39 AM(UTC)
Appliance Ninja
Great! That part will need to be replaced and is available at the link below!
Whirlpool 12555902 Overload, Relay - AppliancePartsPros.com
plout99
#13 Posted : Saturday, November 23, 2013 11:05:09 AM(UTC)
plout99
Can the relay be "hot wired" so it will work untill I get the part?
Thanks,
Jeff
Appliance Ninja
#14 Posted : Saturday, November 23, 2013 11:10:57 AM(UTC)
Appliance Ninja
No, because the power must initially come in to the start winding then switch to the run winding.
plout99
#15 Posted : Tuesday, November 26, 2013 6:13:20 PM(UTC)
plout99
Ok...I replaced the overload relay with a new one from app.com and it still clicks and will not start the compressor...sounds just like the old one did....suggestions?
Thanks,
Jeff
plout99
#16 Posted : Friday, November 29, 2013 12:38:06 PM(UTC)
plout99
Adding a little more info...The fridge started cooling it maintains 24-30 on the top shelf with the temp control on the coldest setting. I unplugged it to move it back into its spot and it did not restart again. I can hear the relay clicking and trying to start when its out away from the wall... Suggestions on what to look at now??
plout99
#17 Posted : Thursday, December 5, 2013 1:39:08 PM(UTC)
plout99
Ok pulled the new relay off and it rattles like the old relay did.... bad relay? suggestions? when the compressor does start it will drop the fridge to 20 degrees so I assume the compressor is fine....
Thanks,
Jeff
2 Pages<12
