Rwsq
#1 Posted : Thursday, November 21, 2013 11:11:34 AM(UTC)
Rwsq
Purchased new safety valve regulator removed old took off orfice has markings lp with arrow on way and on other side it has nat with arrow facing other way. Does arrow indicate gas flow? For LP do I put arrow going with the flow of gas?
Appliance Ninja
#2 Posted : Thursday, November 21, 2013 12:39:08 PM(UTC)
Appliance Ninja
That plug compresses a spring in the regulator, so if you are using LP, make sure the plug side that says LP is up. The plug is not directional, it is just there to compress the spring, so the way the arrow is sitting is irrelevant.
