washer was making vibrating noise. code 3e came up & washer stopped. thanks.washer off drum will turn slightly then locks up like something was blocking it. want to know what to look for & if the machine gets serviced/repaired from the front or back?
The 3E error is a motor restriction error. Can you manually turn the tub and does it turn smoothly?
drum barely turns and when it does it binds and makes clunking noise.
Okay, so that means the tub support is likely broken, making replacing the spin tub assembly necessary. If you lift up and down on the inner tub, does it have a bit of play and knock?
tub support is broken. split plastic halves and pulled put steel drum. can I just replace the support and how is it coupled to the drive assembly? cant tell because center hub of tub support is stuck on shaft.
