3 Pages<123
sheriowaso
#21 Posted : Wednesday, November 20, 2013 6:16:49 AM(UTC)
sheriowaso
Had to force it.
Appliance Ninja
#22 Posted : Wednesday, November 20, 2013 6:45:51 AM(UTC)
Appliance Ninja
That shaft was likely placed in the wrong position when it was inserted. It is "keyed" with a small plastic tab that should align when inserting.
sheriowaso
#23 Posted : Wednesday, November 20, 2013 11:24:04 AM(UTC)
sheriowaso
Can he just take it out and reinsert it correctly? Thank you!
Appliance Ninja
#24 Posted : Wednesday, November 20, 2013 12:34:01 PM(UTC)
Appliance Ninja
Yes, unless it damaged the control when it was inserted.
sheriowaso
#25 Posted : Wednesday, November 20, 2013 12:59:05 PM(UTC)
sheriowaso
He'll try that tonight. I ran another load through the dryer this afternoon, now it's stopping after 10 minutes of drying. The timer says 1 hour, because I can't change the selection from Towels/Bedding, but it shut itself off after 10 minutes. The back of the dryer gets hot at the top, stays cool in the middle and bottom. Surely that isn't connected to the knob being on incorrectly?
Appliance Ninja
#26 Posted : Wednesday, November 20, 2013 2:45:31 PM(UTC)
Appliance Ninja
Does it have to cool before it will start again?
sheriowaso
#27 Posted : Wednesday, November 20, 2013 3:03:41 PM(UTC)
sheriowaso
No, it started immediately after shutting off & ran for exactly 10 minutes again.
Appliance Ninja
#28 Posted : Wednesday, November 20, 2013 3:55:29 PM(UTC)
Appliance Ninja
That could be control related. I am beginning to think you may need a visit from an on site technician. You have some strange things going with that machine....
sheriowaso
#29 Posted : Wednesday, November 20, 2013 6:45:14 PM(UTC)
sheriowaso
We're getting to that point, too. We figured out that the dryer was shutting off because I kept starting it with dry clothes in it, instead of a wet load of laundry. My fault :o. But he re-installed the knob and it worked like normal right when he did that, but when we tried to run a load of towels through about an hour later, the knob wasn't working again! I guess he could have damaged it the first time he installed it incorrectly - can we buy the part to fix that, or would we need another new control part? He wants to try to fix that, but if we're still having problems then we'll call someone out.
Thanks for all your help!
Appliance Ninja
#30 Posted : Wednesday, November 20, 2013 6:50:45 PM(UTC)
Appliance Ninja
Hopefully it just damaged the pin, available below. If not, the control can be replaced under warranty.
Frigidaire 134347700 Pin - AppliancePartsPros.com
Guest (6)
3 Pages<123
