pbgsho10
#1 Posted : Tuesday, November 19, 2013 8:09:20 AM(UTC)
pbgsho10
When the oven is set to bake the broiler comes on. The stove began beeping and displayed an F10 fault code.
pbgsho10
Appliance Ninja
#2 Posted : Tuesday, November 19, 2013 8:24:50 AM(UTC)
Appliance Ninja
The F10 error means that the temperature is unable to be controlled by the oven controller. The broil relay has welded contacts and the oven control will need to be replaced. The correct one for your model is available at the link below. It is accessed for replacement by removing the access panel at the back of the control panel.
Frigidaire 316418702 Clock/timer - AppliancePartsPros.com
You will also need the sticker overlay for the new control, available at the link below.
http://www.appliancepartspros.c...316419802-ap3771323.html
