maxoutrod
#1 Posted : Tuesday, November 19, 2013 5:59:21 AM(UTC)
maxoutrod
Machine catches water fine, wash, comes to end of cycle no spin. Clock ticks, move to next cycle, washes, same problem. At the end of cycle water is still in machine. Tried it on spin cycle alone, clock ticks, no tub movement. Help!!!!:(
Appliance Ninja
#2 Posted : Tuesday, November 19, 2013 6:40:30 AM(UTC)
Appliance Ninja
Initially, I thought your lid switch may be not closing, a very common problem. However, the timer would not advance if the switch was not closing, so I don't think it is going to be that easy. I suspect you may have an issue with the timer. If you set the machine to s pin cycle and move the knob up and down and side to side, will the spin cycle start? Do you have a meter to test voltage with?
