gregaguilar
#1 Posted : Monday, November 18, 2013 5:23:12 PM(UTC)
gregaguilar
this unit is not getting cold enough on both compartments it is a side by side unit and I would like to get a service manual on it so i can diagnose the problem any help is appreciated thanks
Appliance Ninja
#2 Posted : Monday, November 18, 2013 6:10:19 PM(UTC)
Appliance Ninja
The error code you are seeing indicates an issue with the defrost circuit. There is frost built up on the evaporator coil in the freezer that is obstructing the air flow. That is why the temperatures are not good. The most common component to fail is the controller assembly, which houses a thermistor and thermal fuse. You can test the thermal fuse for continuity through the black and blue wires. No continuity means the fuse is open and the assembly will need to be replaced. That part is mounted on the evaporator coil, behind the rear wall inside the freezer. The correct controller for your model is available at the link below.
LG 6615JB2002R Controller Assembly - AppliancePartsPros.com
gregaguilar
#3 Posted : Monday, November 18, 2013 6:32:43 PM(UTC)
gregaguilar
appliance ninja you are great thanks manana i will see and test that bad hombre
Appliance Ninja
#4 Posted : Monday, November 18, 2013 6:36:55 PM(UTC)
Appliance Ninja
Roger that, keep me posted! Have a great evening!
gregaguilar
#5 Posted : Tuesday, November 19, 2013 4:31:20 AM(UTC)
gregaguilar
NINJA is there a site for a service manual I forgot to ask last nite thanks
Appliance Ninja
#6 Posted : Tuesday, November 19, 2013 6:09:11 AM(UTC)
Appliance Ninja
I don't have the exact manual, but the one below is to a comparable LG product.
LG SxS Manual
