errolarena
#1 Posted : Monday, November 18, 2013 7:38:46 AM(UTC)
errolarena
I have water leaking out of top of freezer door, and there is ice in bottom of freezer. I need to know where the drain pan is located and why this might be happening.
Appliance Ninja
#2 Posted : Monday, November 18, 2013 7:44:40 AM(UTC)
Appliance Ninja
Your defrost drain is plugged and not allowing the water from the defrost cycle to drain to the condensate pan, located below the cabinet by the compressor. That drain is positioned under the evaporator coil in the freezer, behind the rear wall. You can totally disassemble the freezer to remove the rear wall and manually thaw it, or just turn the unit off for about 12 hours with the doors open, a much easier solution. Of course, the food will need to be moved to a different location.
errolarena
#3 Posted : Monday, November 18, 2013 7:54:40 AM(UTC)
errolarena
What if it is the icemaker inside the refrigerator doing it? How do I find the drain inside the ice maker?
Appliance Ninja
#4 Posted : Monday, November 18, 2013 7:59:36 AM(UTC)
Appliance Ninja
It sin't the ice maker or the ice cube tray would have to be full and leaking. The drain is at the back of the freezer, behind the panel shown as number 11 below. It will require all components to be removed from the freezer to get that panel off.
Appliance Ninja attached the following image(s):
Guest (4)
