Help. I have posted my problem before but no one seems interested. Second try: Can someone scan me a page of the schematics of Amana washer model LW8203W2. If received, I will not bother readers with threads on this model again. I promise.
Rank: Administration
Groups: Guests
Narapni, It's not a bother at all. Unfortunately, after spending about an hour I cannot find a wiring diagram for LW8203W2 anywhere. What I do have for you is a service manual for Amana top load washers. I hope this helps. - Click here for the manual Let us know how it goes.
Thank you very much. I pored thru the manual but could not find the one page I needed most--the wiring diagram of the Amana Top loading washer. I would really appreciate just the one or two pages showing the wiring diagram and the schematics. The model is LW8203W2, Mfr P number is PLW8203W2B.
I have the wiring diagram. Mine was located inside the back of the switch panel. Three screws on top of the back and it pulls forward, and I had a slip of paper in there with the wiring diagram. If you don't find it, I could fax it to you. Kenton Originally Posted by: Narapni ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you very much. I pored thru the manual but could not find the one page I needed most--the wiring diagram of the Amana Top loading washer. I would really appreciate just the one or two pages showing the wiring diagram and the schematics. The model is LW8203W2, Mfr P number is PLW8203W2B.
Thank you very much. My fault I did not mention that the original schematics may have been removed by prior techs or eaten by bugs.
Anyway, I could still use the schematics. I have seen some scanned schematics but they came out blurred so perhaps faxing is better. I will alert you of the fax number at a later date.
