Kenmore wall oven and microwave made by Frigadaire. Need new microwave, repairman said that it is not repairable. I want to replace microwave only.
What is the microwave doing that it cannot be repaired?
Microwave actually caught fire and is damaged very extensively
Oh, yeah, that would condemn it. I will see what I can come up with for a replacement but with the Kenmore model it will not be easy. I will see what I can find, though.
You bet, I will post what I can find. If you can post the dimensions from your existing microwave, it may help.
Ok 19.25 deep ,23.75 wide and 13 high. Bolt pattern on bottom 11.5 by 19.5, but I"ll make the micro fit if the dimensions are ok.
