I have a ge model dde5300velha, it has little to no heat. I would like any "how to's" on what to do?
Your dryer uses two heating element coils. It is likely that one has broken and you are only getting heat from one coil. The coils are in the housing behind the drum and are accessed only by totally disassembling the machine. However, you can test the coils by raising the top, if you have a meter to test with. Do you have access to a multimeter to test with?
