korean1
#1 Posted : Saturday, November 16, 2013 6:53:18 PM(UTC)
korean1
Washes clothes fine. But when spinning the sound is extremly louder. Has increased in the past few days. Am I expecting a bearing or something going out?
fairbank56
#2 Posted : Sunday, November 17, 2013 4:31:36 AM(UTC)
fairbank56
Groups: Expert
Depends on the sound. Can you post a video to youtube so we can hear it? Tilt machine back, remove belt guard and make sure the larger drive pulley nut hasn't loosened (common problem). If it has, apply some Loctite blue 242 threadlocker to the threads before tightening. If that is not the problem, could be bearings in transmission (not serviceable) or dry seals. Here is a bulletin on the dry seal problem.
Eric
UserPostedImage
korean1
#3 Posted : Sunday, November 17, 2013 5:57:40 AM(UTC)
korean1
Awesome info. Here is a load I did today. Normal weight load. No issues with balance.
This seems a little quieter than it was last night during spin. That load could have been heavier as well than todays.
https://www.youtube.com/watch?v=...ure=youtube_gdata_player
fairbank56
#4 Posted : Sunday, November 17, 2013 6:15:25 AM(UTC)
fairbank56
Groups: Expert
That sounds like gearcase bearings to me. You would have to replace the gearcase.
Whirlpool W10330039 Gearcase - AppliancePartsPros.com
Eric
korean1
#5 Posted : Sunday, November 17, 2013 6:26:54 AM(UTC)
korean1
Figured as much. Thanks for the help!
korean1
#6 Posted : Saturday, November 23, 2013 11:01:59 AM(UTC)
korean1
Is there a video of this gear box replacement? Or anything close? Special tools?
