2 Pages12>
Appliancetard
#1 Posted : Monday, December 31, 2012 7:56:10 PM(UTC)
Appliancetard
Mod. RBD305PRB00
Ser. XW1807134
Okay, so after cleaning pie filling off of the bottom of my top oven, I decided to run an "autoclean" cycle and get rid of the rest of the gunk from the past 4 years. About 2/3rds of the way through the cycle I thought it would be interesting to try and look up why they don't include an autoclean cycle on the bottom oven. Instead, I found a lot of people posting how their oven had locked up or quit working when they ran the self-clean feature. Instead of canceling the cycle, although my whole house already smelled like burning electrical parts at that point, I thought I would take my chances.
Well here I am, 2 days later, with a top oven that doesn't work. THANK GOODNESS they only have autoclean for the top oven!
When I turn my oven on, it acts normal. The preheat runs the same and it beeps and tells me it is all ready to go at 350*, but in reality neither filament is hot at all. What is wrong? How can I fix this? Thanks for your help in advance.
#2 Posted : Thursday, January 3, 2013 1:22:15 AM(UTC)
Parts for Whirlpool RBD305PRB00 Wall Oven - AppliancePartsPros.com
Odds are you blew the thermal overload (item 37 in the Upper Oven Parts section).
Would not hurt to also check your oven sensor, see the belo link and items 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
File Attachment(s):
RBD305.pdf (518kb) downloaded 22 time(s).
Appliancetard
#3 Posted : Friday, November 15, 2013 1:46:19 PM(UTC)
Appliancetard
Thank you for the reply denman. I am just now almost a year later getting around to fixing this. Anyway, I have ordered the thermal overload and am trying to research replacing it. Do I have to pull my wall oven out of the cabinet to access the part? I'm assuming that is what is required for the sensor as well if needed. Any help anyone can give is appreciated. Thanks again.
#4 Posted : Saturday, November 16, 2013 4:48:57 AM(UTC)
[COLOR="Blue"]Do I have to pull my wall oven out of the cabinet to access the part?[/COLOR]
Yes
Appliancetard
#5 Posted : Tuesday, November 19, 2013 2:43:28 PM(UTC)
Appliancetard
Okay, I replaced the thermostat and it is still not working. I checked the heating filaments and they work fine. I haven't replaced the sensor, but I'm assuming the oven would heat up even if the sensor was not working.
The fan kicks on and makes all of the noises like it is heating, the oven tells me it has heated up to 350 degrees, but there is no heat.
Any other suggestions? I was so excited to be able to fix this myself, but really have no idea what else may be wrong. :confused:
#6 Posted : Wednesday, November 20, 2013 1:57:36 AM(UTC)
[COLOR="Blue"]Okay, I replaced the thermostat and it is still not working.[/COLOR]
Did you check the old one before replacing it?
Was it blown?
[COLOR="Blue"] I checked the heating filaments and they work fine. I haven't replaced the sensor, but I'm assuming the oven would heat up even if the sensor was not working.[/COLOR]
Depends what is wrong with the sensor.
If the sensor is giving an incorrect reading then the control board could think that the unit is up to set point temperature and therefore does not turn the elements on.
[COLOR="Blue"]The fan kicks on and makes all of the noises like it is heating, the oven tells me it has heated up to 350 degrees, but there is no heat.[/COLOR]
If the sensor resistance is about 1,100 at room temperature then odds are that the control board is shot.
Unit thinks that the oven is at set point when it is not.
Appliancetard
#7 Posted : Wednesday, November 20, 2013 9:54:06 AM(UTC)
Appliancetard
1, 2, 3, 4, 5, 6, 7, 8, 9, 10.
Appliancetard
#8 Posted : Wednesday, November 20, 2013 9:54:51 AM(UTC)
Appliancetard
So can I use the same voltmeter thing to check the thermostat and the sensor? I don't have one yet, but want to make sure I get the right thing. Also, I see the chart for the proper resistance, but I am not sure how to check the sensor, where I put the probes I mean.
Thank you for your help denman. I'm sure that control board is not cheap if that turns out to be the problem.
#9 Posted : Wednesday, November 20, 2013 10:23:03 AM(UTC)
Below is info on a meter.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Appliancetard
#10 Posted : Thursday, November 21, 2013 9:46:28 AM(UTC)
Appliancetard
I tested the thermostat on the lowest ohm setting of 200 and it tested bad with the number 1 all the way on the left. I tested the good one just to make sure I was doing it right and it was good with the number being 0.
I tested the oven sensor, it wouldn't measure at the lowest ohm setting, so I moved it up to 2000 ohms and it tested at right around 1080. I also tested the good one to see how it compared and it tested around the same, also setting the multimeter at 2000 to get a reading.
I notice the sensor from the non-working oven is much darker and dirtier than the lower oven, but this is probably just from use.
I tried taking the sensor from the good oven and putting it in the bad oven just to see what that would do, but when I pushed the oven on it said, "350" on the display panel, but then kept going black very quickly before I could even push start. It finally gave me an error code. In green it said F3 and in smaller yellow it said E2.
Now the error code is E0 F3 and just a plain F3. Now I'm starting to wonder if I got the oven sensors mixed up and put the one from the bad oven back in.
Guest (7)
2 Pages12>
