Mistyjoyner
#1 Posted : Friday, November 15, 2013 1:26:38 PM(UTC)
Mistyjoyner
The fridge and freezer no longer is getting cold. There is no air blowing and the compressor is not hot. What could possibly be the problem?
Appliance Ninja
#2 Posted : Friday, November 15, 2013 1:30:37 PM(UTC)
Appliance Ninja
If no fans are running, you have a control issue. Tap the temperature controls with a screwdriver handle and see if it comes on. Let me know what happens, please.
#3 Posted : Saturday, November 16, 2013 5:17:23 AM(UTC)
Parts for Whirlpool ED5PHEXMQ00 Refrigerator - AppliancePartsPros.com
Since the fans and the compressor are not running it could be one of two problems.
1. A bad control thermostat.
2. You are stuck in a defrost cycle.
Instead of hitting the thermostat (item 9 in section 11) just turn the cold control up/down a bit.
If the unit fires up then I would replace the thermostat.
If this does nothing. Turn the defrost timer (item 6 in section 11) cam with a flat screwdriver. There is usually a hole in the cover to let you do this without any dis-assembly.
The turning is better than tapping because tapping may effect both the thermostat and the timer so you cannot tell which one is bad.
