syllinx
#1 Posted : Friday, November 15, 2013 5:11:38 AM(UTC)
syllinx
The wires connecting to bottom heating element in oven melted. Everyting else works fine. Does anybody know if I can just replace the bottom heating element and cut a splice same gauge of wire to make it work again?
Appliance Ninja
#2 Posted : Friday, November 15, 2013 7:06:57 AM(UTC)
Appliance Ninja
That will work fine, but use of a high temp wire and terminals as well as ceramic wire nuts is recommended.
syllinx
#3 Posted : Friday, November 15, 2013 7:08:41 AM(UTC)
syllinx
I will order the part today and see how it goes next week I hope.
Appliance Ninja
#4 Posted : Friday, November 15, 2013 7:10:02 AM(UTC)
Appliance Ninja
Sounds good! Let me know if you run into trouble during install. Have a great weekend!
kcag_barry@yahoo.com
#5 Posted : Monday, March 6, 2017 5:23:18 AM(UTC)
GE does not sell the wires and connectors as parts. They said it is part of the main harness and they don't sell those. Do generic clips come in a heat rating that is high enough for the oven? Do you know if they sell high temp wire and terminals at Home Depot or Lowes?
ThatGuy
#6 Posted : Monday, March 6, 2017 6:23:23 AM(UTC)
ThatGuy
Groups: Expert
United States
I always used high temp 12 gauge wire whenever possible and high temp steel crimp on terminals. If I remember right they were rated for 900 degrees F.
The 1/4 inch one in the lower right of this picture is the one I used most of the time.
UserPostedImage
I don't know if they sell them at the hardware stores, but they might.
High Temperature Wire Terminals | Hi Temp Crimp Terminals | ElecDirect
Guest (6)
