4 Pages<1234>
Appliance Ninja
#11 Posted : 11 years ago
Appliance Ninja
They will be single wires on the relays marked with a yellow dot. Those wires run down to the bake elements.
jwmingus
#12 Posted : 11 years ago
jwmingus
I have the two yellow shown here. Going into the panel back
I will pull both. Tape off Wire end. Then apply power to the oven.
Turn on oven, then test connection at panel ?
[IMG]https://mail.google.com/mail/?ui=2&ik=20d9c5d003&view=att&th=1425953af2d75adb&attid=0.1&disp=thd&zw[/IMG]
Appliance Ninja
#13 Posted : 11 years ago
Appliance Ninja
Correct, turn each oven to bake and measure power at the now empty terminals and see if they read 120 VAC from the terminals to ground.
jwmingus
#14 Posted : 11 years ago
jwmingus
please point me to ground. dont wanna die tonight
Appliance Ninja
#15 Posted : 11 years ago
Appliance Ninja
Any metal surface on the oven is ground. Sorry I did not clarify that.
jwmingus
#16 Posted : 11 years ago
jwmingus
Done - 0 on each test. Some Clicking of Relays.
Appliance Ninja
#17 Posted : 11 years ago
Appliance Ninja
Excellent, very well done! That confirms the oven control is faulty. The correct one for your oven is available at the link below.
GE WB27T10282 Electronic Oven Control - AppliancePartsPros.com
jwmingus
#18 Posted : 11 years ago
jwmingus
Thanks for the Help. I guess cheaper than a whole new unit.
I really appreciate the guidance.
Appliance Ninja
#19 Posted : 11 years ago
Appliance Ninja
You are very welcome, you did a great job! Let me know if you run into trouble during installation of that control.
jwmingus
#20 Posted : 11 years ago
jwmingus
Hi Ninja, Received the new control unit. But - More connections on this one than the old one... Are we sure this is a one for one newer part?
4 Pages<1234>
