2 Pages12>
ashtreylil
#1 Posted : Thursday, November 14, 2013 3:35:32 PM(UTC)
ashtreylil
My whirlpool duet washing machine stopped working a month ago. The machine will not power on. the only response i get are 3 short beeps when pressing the power button. UserPostedImage
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 3:47:35 PM(UTC)
Appliance Ninja
You likely have a faulty motor control that is causing issues with the machine control. You can verify this pretty easily. Remove the screws from the rear edge of the top panel and remove that panel. In the RF corner of the machine you will see the machine control. With the machine unplugged, locate the connector in the spot labeled MI3 on the control and carefully remove it. Then, plug the machine back in and see if it will power up. Let me know what happens, please.
ashtreylil
#3 Posted : Thursday, November 14, 2013 4:11:39 PM(UTC)
ashtreylil
UserPostedImage
UserPostedImage
UserPostedImagei dont see a plug labeled like that
Appliance Ninja
#4 Posted : Thursday, November 14, 2013 4:16:53 PM(UTC)
Appliance Ninja
That is the wrong control, the control that connector is on is pictured at the link below, mounted on the RH side near the front of the machine.
Whirlpool 8183259 Electronic Control Board - AppliancePartsPros.com
ashtreylil
#5 Posted : Thursday, November 14, 2013 4:40:36 PM(UTC)
ashtreylil
UserPostedImage
What is is the sensor attached to MI3? I got it to work to where the dial can show the times and the normal wash could activate.
Appliance Ninja
#6 Posted : Thursday, November 14, 2013 4:49:52 PM(UTC)
Appliance Ninja
Did you disconnect the connector that is labeled MI3 on the board or what did you do to get the control to light up instead of just beep?
ashtreylil
#7 Posted : Thursday, November 14, 2013 4:58:52 PM(UTC)
ashtreylil
yes i disconnected the mi3 plug, what is the sensor connected to? is the machine operational with the sensor disconnected? it seems to be in working order now that the plug is disconnected.
Appliance Ninja
#8 Posted : Thursday, November 14, 2013 5:03:24 PM(UTC)
Appliance Ninja
By removing that plug, you isolated the motor control away from the main machine control. The motor control is shorted and will need to be replaced. The drum will not move with that part being bad. The board you need is available below and is mounted to the bottom of the machine, accessed by removing the rear access panel.
Whirlpool 8183196 Cntrl-Elec - AppliancePartsPros.com
ashtreylil
#9 Posted : Thursday, November 14, 2013 5:07:35 PM(UTC)
ashtreylil
are you sure that that is the issue with my machine? could there be another issue causing the same problems?
Appliance Ninja
#10 Posted : Thursday, November 14, 2013 5:09:42 PM(UTC)
Appliance Ninja
I am very confident that is the problem. That is why I had you isolate the motor control, it makes diagnosis very accurate and simple. This is a very common problem. Replacing that board will get you back up and running.
Guest (4)
Whirlpool Duet 3 beeps won't turn on (Washer Repair)
by J Chambers 7/12/2018 8:04:16 AM(UTC)
2 Pages12>
