I replaced the ignitors in both ovens of this O'Keefe & Merritt gas stove, one in the lower oven, the other in the upper oven above the cooktop. There's a work light (panel behind the cooktop) and above that is the upper oven. Took the chrome strips off the glass work light panel to clean the glass, etc. I am ready to slide the glass back into place & screw on the supporting chrome strip on either side of the glass. Problem is that I have 2 identical "support braces" (each has one screw) that go somewhere around this work light area and I can't figure out where they go. Ughhhhhh... can anyone help? Just plugged it in (gas still off to it) and it's making a buzzing noise ...
I just noticed your older post and have no help, sorry. BUT...hopefully you can help me...Where did you get your new igniters and did/do you have a part number or something I can use to try and find them ? Like your issue, I'm having a devil of a time with the parts. Thank you so much for the consideration and hope you eventually solved your problem. Regards, Tom tmbeidleman@eathlink.net
