crazyoldchick
#1 Posted : Thursday, November 14, 2013 7:27:19 AM(UTC)
crazyoldchick
I have a Maytag Gemini double oven and am having problems with the lower oven. It heats to ~275 degrees, but no hotter. The lower element doesn't heat at all, but we had it tested and it tests fine. What could cause this issue and how do I fix it???
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 7:29:37 AM(UTC)
Appliance Ninja
Does the broil element work in the lower oven? Do you have a meter to test voltage with?
crazyoldchick
#3 Posted : Thursday, November 14, 2013 7:39:08 AM(UTC)
crazyoldchick
Yes, the broil element works. I do not have a volt meter.
Appliance Ninja
#4 Posted : Thursday, November 14, 2013 7:45:10 AM(UTC)
Appliance Ninja
If the broil element works, then you will likely need to replace the oven control, the part that sends the power to the bake element. You could also have a wire off or burnt, but that would be unlikely if you did not see anything when you had access to the element. The correct control for your model is available at the link below.
Whirlpool 5701M403-60 Cntrl-Elec - AppliancePartsPros.com
crazyoldchick
#5 Posted : Thursday, November 14, 2013 7:46:50 AM(UTC)
crazyoldchick
Thank you. That is what I thought, but wanted verification.
Appliance Ninja
#6 Posted : Thursday, November 14, 2013 7:49:11 AM(UTC)
Appliance Ninja
You are very welcome. Have a great day in spite of it!
Guest (5)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by Tigerpa 1/4/2014 9:56:27 AM(UTC)
lower oven won't heat (Oven Repair (including Ranges and Cooktops))
by rleescott 7/28/2013 8:07:59 AM(UTC)
