I Have A Maytag French Door Fridge And It Was Not Cooling Fridge Tested Evap Cooling Fan And Found To Be Faulty. Replaced The Fan And Now I Have No Cooling At All To Either Fridge Or Freezer And The Fan Will Cut Out And The Temp Control Lights Will Flash For A Second Approx Every 10-30 Seconds, The Pulsating Also Makes The Evap Fan Stop Just For A Second, Any Thoughts
Hm, it is hard to say, but probably your problem is the control board. For this type of refrigerator repair I strongly recommend you to call the tech. GL anyway
French door refrigerators are one off the most advance and energy efficient refrigerators available in the market. Due to huge collection of kitchen appliances available in the market its quiet hard to make a right choice. Most of consumer affair analyst recommend before buying a product feedback about the product can help you to make a better selection.
