Sarah Gifford
#1 Posted : 11 years ago
Sarah Gifford
The control panel just keeps flashing 12:00. It will not let me set the clock, turn the oven on nothing it just flashes 12:00.:cool:
Appliance Ninja
#2 Posted : 11 years ago
Appliance Ninja
If the control is not responsive at all, the touch panel may be bad or the control if it is an integrated control. May I please have your model number so I am able to provide you with accurate, model specific information? The tag is likely behind the lower drawer, usually on the LH side.
Sarah Gifford
#3 Posted : 11 years ago
Sarah Gifford
I am not sure it is not on the range and my book doesn't show a model # that I can find. WFG361LVQ 273, or maybe W10196153B.
Sarah Gifford
#4 Posted : 11 years ago
Sarah Gifford
I does say Accubake.
Appliance Ninja
#5 Posted : 11 years ago
Appliance Ninja
Perfect, thank you! That uses an integrated control, so if you turn the breaker off for 5 minutes and back on and it still won't work, the oven control will need to be replaced. The correct control for your model is available below. It is accessed by removing the access panel from the back of the range. The control simply unplugs and plugs in, making for a very easy repair.
Whirlpool W10424331 Electronic Control Board - AppliancePartsPros.com
Sarah Gifford
#6 Posted : 11 years ago
Sarah Gifford
Your a genius thank you so much.:)
Appliance Ninja
#7 Posted : 11 years ago
Appliance Ninja
You are very welcome! Please post back if you have questions during install!
Flashing 12:00 (Oven Repair (including Ranges and Cooktops))
by Sarah Gifford 11 years ago
