I have a front loading Maytag 2000 series washer that isn’t working, model # MWWE200XW00. My problem began when the washer locked up on me when it was in an unbalanced condition. It also tripped a circuit breaker at that time.
After using the interior release to open the door, when I try a new cycle, it locks the door but does not start. Further, the light indicating door locked is illuminated along with the light that states add clothes.
I got into the diagnostic mode and the error code was LF, which means no water detected entering washer or pressure switch trip not detected. I reset the code and have tried the automated test. During the automated test I hear and see water filling in the tub, then I hear the pump and see the water being removed from the tub. There is no tub spinning, however, and the pump continues to run until I unplug the washer. Through the front access panel I can see the belt is in place around the motor pulley and I don’t hear any noises indicating the motor/tub are attempting to turn. Manually, the tub will turn freely and is not bound up.
What are your thoughts?
Whirpool duet Sport Will not work has power wants to turn but will stop, and make a loud click sound. Model #wfw8300sw02 Thanks Jesus F
I am experiencing this exact same problem. Any resolution?
