AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Super Capacity Washer - Not Running - Just Hums
Okay, but if you push on or move the white connector on the motor, it will spin?
Yes with it all back together it now fills and onced fills hums and if I turn the dial to spin it doesnt make any noise at all
I believe that connector on the motor harness will need to be replaced. May I please have your model number so I am able to provide you with accurate, model specific information?
Groups: Expert
Originally Posted by: snadeau ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Mine is doing this same thing. I replaced the lid switch and the motor drive switch. The machine will fill but won't spin. If I manually push the white button on the motor switch it will spin. What could be wrong? Please help :) You replaced the centrifugal switch on the motor or did you replace the timer? What white button on motor switch? By spin, do you mean agitate? Washer should agitate after filling. If you advance timer to drain or spin, will it drain or spin? I wouldn't go ordering an entire wiring harness at this point til we understand exactly what the problem is. If you have a bad wire/terminal at the motor connector, it can be replaced individually, vice replacing the entire wiring harness. Eric
Washer Repair
