AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
How do I access the heat element & thremal fuses?
I removed the top of the dryer and tried to remove the back panel, the back panel seemed to be riveted onto the side panels. How do I gain access to check and change the heating element or the thermal fuses?
Thanks, RJess
I could not find any info on the given model number tries AppliancePartsPros and the Sears site. I can tell you that the unit was made by LG. Below is a link to a site that has manuals. http://appliancejunk.com/forums/index.phpYou will have to join the site. Then go to the Manuals page and look at the Dryer Service Manuals with luck you will find one that is a close match to your unit. on page 2 there is a manual which covers lots of LG's. I do not havew a Sears to LG model number cross reference so do not know what the LG model number would be. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
