rhemshot
#1 Posted : Wednesday, March 13, 2013 3:06:16 PM(UTC)
rhemshot
Please help!!! Ice maker makes ice but will only dispense on the crushed icesetting and will not dispense cubed ice. When the cubed ice button is selectedcrushed ice comes out. Crushed ice also comes out when the crushed ice settingis selected. Is there a lever that needs to be adjusted?
G.E. Refrigerator
Model: GSH25JSTASS
Serial: FM206799
Simon / APP Team
#2 Posted : Wednesday, March 13, 2013 5:23:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is the ice cube solenoid assembly next to the crasher motor behind the ice bin.Open the motor cover and check the solenoid.
Here are the breakdown diagrams and Ice Maker & Dispenser parts for GE GSH25JSTASS - AppliancePartsPros.com
Post the results.
Simon.
rhemshot
#3 Posted : Friday, November 8, 2013 2:19:15 PM(UTC)
rhemshot
I can tell the ice cube solenoid assembly is working by opening the freezer door, pressing my finger on the door sensor to show that the door is closed, and press the cube ice button, press the lever to see the Stirrup Solenoid Display slide up. When I press the crushed ice button the Stirrup Solenoid Display stays down. The ice comes out crushed both ways.
