Pat Cochran
#1 Posted : Thursday, November 7, 2013 4:19:33 AM(UTC)
Pat Cochran
When the dishwasher start button is pushed, the water begins to come in and after a couple of minutes there is a loud buzz for a few seconds and then nothing. There is nothing jammed anywhere. I have taken the motor off and it runs good. Thanks, Pat
Pat Cochran
#2 Posted : Friday, November 8, 2013 9:05:11 AM(UTC)
Pat Cochran
OK, I have found out that the motor IS bad. Seems that the bearings are loose which makes it run noisy. It will only start when the motor is turned to a certain position. Most positions will not start.
