flatcity
#1 Posted : Tuesday, November 5, 2013 11:11:58 AM(UTC)
flatcity
How do you test a transformer for a whirlpool double oven #RBD245PDS14
#2 Posted : Tuesday, November 5, 2013 11:54:55 PM(UTC)
Parts for Whirlpool RBD245PDS14 Wall Oven - AppliancePartsPros.com
It gives the winding resistance values.
When checking be sure to disconnect at least one side of the winding. This prevents you from reading al alternate/parallel circuit path.
Also be sure to use the most sensitive meter scale that is at least 100 ohms and short the meter leads together before starting so you can see if the meter has a zero offset.
If you do a live test the primary will have 120 volts AC.
I am not sure what the secondary voltage will be.
FYI: Note that there is a thermal fuse in the primary circuit.
File Attachment(s):
RBD245.pdf (505kb) downloaded 5 time(s).
