Left front burner will not operate on "LO" or "SIM" settings. Does not begin to heat until setting #2, at which point I can hold my hand on the cooktop. Works OK on settings higher than Medium. I have replaced the infinite control and the burner itself, as well as one connector that looked a little 'toasty' (although I think it was OK. Tested fine.).
What am I missing? I believe the thermal limiter is integral to the burner, is it not?
