Heifinator
#1 Posted : Saturday, November 2, 2013 11:11:14 AM(UTC)
Heifinator
I have never done much work on dishwashers so pardon the noobness.
model: WDT710PAYM3
The control panel is acting weird, all the buttons make a sound when pressed but when I click start nothing happens, some buttons don't light at all. Reset breaker to the unit and did the control board reset (heat + dry repeatedly or wahtever), didn't work.
Needing to know the proper steps to troubleshoot this! Thanks all.
Heifinator
#2 Posted : Tuesday, November 5, 2013 8:21:05 PM(UTC)
Heifinator
replaced control board, worked once now having same problem again, assuming its the button inteface bar across the top, only other part I can think that would cause this.
