exptech
#1 Posted : Wednesday, October 30, 2013 6:36:02 AM(UTC)
exptech
Unit works fine except heavy frost builds up on low side Freon line from compressor to case and melts and drips on floor when unit cycles off.
Noticed a fill port has been installed on this line, Would a improper Freon level cause this. I have proper equipment to service this but cannot find factory specs on unit.
#2 Posted : Thursday, October 31, 2013 2:41:58 AM(UTC)
Somebody overfilled the fridg with refrigerant. Best to lower the level before damage is done to the compressor.
If the model # plate shows R134A refrigerant, you can open up the line tap on the compressor tubing till the frost level backs away from the compressor.
Be careful not to release too much refrigerant. The gas is rather inert, not hazardous.
exptech
#3 Posted : Thursday, October 31, 2013 5:57:22 AM(UTC)
exptech
Released a small amount of Freon at the line tap and will watch unit as it cycles to see if more is needed. Thanks for the advice, will keep you informed of the results.
#4 Posted : Thursday, October 31, 2013 12:58:38 PM(UTC)
Be careful here, if the unit will not completely defrost, that will cause the frost line to get extended and you will release too much refrigerant.
Guest (5)
Temperature Sensor for General Electric GTS22KBPDRCC Frost buildup (Refrigerator & Freezer Repair)
by trm655 11/18/2021 12:53:19 PM(UTC)
LG Freezer Frost Buildup (Refrigerator & Freezer Repair)
by joe475 10/18/2020 7:02:31 AM(UTC)
Kenmore Bottom Freezer Frost Buildup (Refrigerator & Freezer Repair)
by EdBurkett 2/10/2018 7:54:23 AM(UTC)
Refrigerator warm, freezer cold, frost buildup on back of freezer (Refrigerator & Freezer Repair)
by Geoff Hess 8/15/2017 8:31:32 AM(UTC)
Ken more side by side frost buildup on coils (Refrigerator & Freezer Repair)
by Mckelvy2716 8/3/2015 11:17:46 AM(UTC)
Kenmore Side by Side Frost Buildup (Refrigerator & Freezer Repair)
by metolius22 7/27/2015 7:30:58 PM(UTC)
Frost buildup problem (Refrigerator & Freezer Repair)
by -Ronin- 6/10/2011 7:04:26 AM(UTC)
frost buildup in freezer, warm below (Refrigerator & Freezer Repair)
by mackisus 9/29/2010 12:21:42 PM(UTC)
frost buildup on freezer wall (Refrigerator & Freezer Repair)
by boulosb 10/30/2009 10:26:08 AM(UTC)
upright freezer frost buildup (Refrigerator & Freezer Repair)
by Paul Keisling 8/11/2009 7:38:23 AM(UTC)
frost buildup in icemaker chute (Refrigerator & Freezer Repair)
by savery 7/14/2009 10:57:05 AM(UTC)
Quick Freeze Area Not Freezing, frost buildup (Refrigerator & Freezer Repair)
by hughes 2/18/2009 5:01:10 AM(UTC)
by Jerryhere 10/1/2008 8:28:00 AM(UTC)
Excessive frost buildup requiring weekly defrost (Refrigerator & Freezer Repair)
by Joe Cal 9/30/2007 9:21:18 AM(UTC)
