Zman57
#1 Posted : Friday, October 25, 2013 9:36:22 AM(UTC)
Zman57
I have found that removing the frost with a hair dryer works for about two days , then they The coils frost over again. I read they threads,and trouble shooting post and found the defroster thermostat reading bad , I replaced it and am still having the same problem, How can I check the adaptive defrost control board to see if it is the problem ?
#2 Posted : Friday, October 25, 2013 12:15:24 PM(UTC)
Parts for Frigidaire FRS26LF7DSR Refrigerator - AppliancePartsPros.com
Here is the tech sheet it has how to force a defrost cycle.
http://manuals.frigidaire.com/p...f/Anderson/240389616.pdf
If the defrost heater comes on then the board is bad.
