hrsmith
#1 Posted : Tuesday, April 14, 2009 6:21:07 AM(UTC)
hrsmith
The right front burner is carboning up. The burner seems to start out burning okay then the frlame changes from all blue to a mixture of blue and yellow. This is the highest heating burner on the stove. Any thing I can do to repair it?
#2 Posted : Tuesday, April 14, 2009 2:09:22 PM(UTC)
Remove the burner cap and the burner head. Make sure all burner parts are clean. If not then use a soft metal brush to clean them. Using a long needle or a toothpick, clean the hole in the orifice spud (#3 on the diagram)
Here are the breakdown diagrams and Replacement parts for GE JGSP48BH6BB | AppliancePartsPros.com
hrsmith
#3 Posted : Wednesday, April 29, 2009 12:12:18 PM(UTC)
hrsmith
I cleaned the burner cap and all areas around and still have the problem. I called the gas company and they cleaned it again still get the yellow flame and a smell not of gas.
#4 Posted : Wednesday, April 29, 2009 5:35:03 PM(UTC)
I do not see what else can cause it. Maybe somebody else on the forum can help you better.
Kenmore gas range problem (Oven Repair (including Ranges and Cooktops))
by Rob66 12/22/2019 3:38:16 AM(UTC)
Self-Cleaning Gas Range Problem (Oven Repair (including Ranges and Cooktops))
by cfloyd 1/19/2011 2:52:24 PM(UTC)
