The Country Toad
#1 Posted : Wednesday, October 23, 2013 2:18:18 PM(UTC)
The Country Toad
hello all..... i have a gemini double mer6770aac. i started getting the f1-1 code a month ago and tried to trouble shoot things down to the panel after reading multiple posts and testing with my fluke.
i replaced the board this afternoon and the oven worked great for 30min but then gave me the f1-1 code and the upper oven top element wouldnt turn off. i had to trip the breaker to get the oven to turn off. scary to say the least.
i thought my temp sensors ohm'd out at 1100 prior to changing my board but now they're reading 1200-1272.
am i looking at bad sensors? i've checked all the connections that i felt came from the board to the oven but i keep reading about a cluster that i may not have found. can someone advise? anyone got any wire colors for the cluster that comes from the board?
thanx all!
brad
The Country Toad
#2 Posted : Wednesday, October 23, 2013 2:36:36 PM(UTC)
The Country Toad
update..... now that the oven is cool the temp sensors are ohm'n at 1000-1100.
The Country Toad
#3 Posted : Wednesday, October 23, 2013 4:08:42 PM(UTC)
The Country Toad
one last update.
both temp sensors ohm ok
old board..... top broiler element doesnt come on
new board...... top broiler comes on when power is applied to the oven and without even turning the oven settings on..... and wont turn off without hitting the breaker. run away.
so what in the world am i looking at?
