ron myers
#1 Posted : Sunday, October 20, 2013 5:17:17 PM(UTC)
ron myers
My dryer works on timed dry., but is intermintent on auto sense dry. the problem is timed dry is only 30 minutes so you have to keep turning it on.
Thanks for any help.:)
#2 Posted : Monday, October 21, 2013 1:20:31 AM(UTC)
Parts for Maytag AED4475TQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram
[COLOR="Blue"]intermintent on auto sense dry[/COLOR]
What is it not doing?
Have you cleaned checked your vent system?
What have you done so far to troubleshoot this.
Check your exhaust temperature. The temperature should get to around 155 degrees F. This is the shut off point of the control thermostat. It closes at 130 degrees F.
File Attachment(s):
AED4475.pdf (182kb) downloaded 5 time(s).
HumboldtRepairMan
#3 Posted : Monday, October 21, 2013 5:52:21 PM(UTC)
HumboldtRepairMan
If you're an avid person that uses liquid fabric softener/certain type of detergents will get on the moisture sensor bars clean them with sandpaper or a wire brush they get residue on them from the softeners and detergents sometimes that affect the dry times of the moisture sensing circuits as well.
bad dryer owner breaks dryer with good intentions. (Dryer Repair)
by arcadeforever 4/13/2009 5:09:58 AM(UTC)
