I get the SUD & F35 error. Ran diagnostic test & get F35 on C:00. I replaced the Analog Pressure Sensor, I can blow the APS hose, cleaned out the trap in front of the pump, drain hoses are clear, cleaned the water inlet strainers, flow meter checks good, steamer passes diagnostic test. Still have error. What next?
Anyone? What are the chances of this new APS being bad?
I have just replaced the APS in Whirlpool Duet Washer WFW9600TW00. Washer worked perfect for 4 loads, then the F35/Sud came back on and it is not working. Have same question - any chance the new switch is bad? Any other suggestions?:confused: brb76 - Did you have any luck figuring it out?
Decided not to sink anymore money into it. Bought a TL Speedqueen.
Ugh. Thanks for the quick reply! Still having problem, everything is cleaned out and have replaced Analog Pressure Switch twice to ensure that it was not a defective switch. Does anyone have an idea for the next step?
