I am having fits with my front load washer. Replaced the motor as it would not run and error code E4a and T10, T11 was verified it was motor. It worked about 4 days then failed again. I have run multiple service tests and now what I find is the spin cycles do not hold at 1000 rpms. It will fill with water then machine will kick into the pause/stop mode. I can unplug it sometimes and it will wash another load or two, then acts up again. Drain filter in the front has been manually drained multiple times.
This sounds like the main control unit, but you will have to replace it on spec.
The good news, if you buy the part from this site and it does not fix the problem you can return it.
You should know this is one of the most troubled machines built, and you may want to consider replacing it.
Originally Posted by: sidfink43 This sounds like the main control unit, but you will have to replace it on spec.
You should know this is one of the most troubled machines built, and you may want to consider replacing it. Is there an easy way of checking the main control? I tried to run the tumble and spin test now and it does nothing.
